Home Made Traction Bar Build
ford rules
You mean like pics from the rear? Ill go grab some.
Here ya go.
Also i dont think i mentioned it but i had to remove the sway bar on the rear also for these to fit, i havent noticed it not being back there.
ford rules
I could take vids of it brake torquing to watch pinion angle movement but no driving vids since I don't have a go pro or anything.
ford rules
Pulled them back off today to prep and paint hope to have em back on this weekend.
ford rules
So the bars are all painted and reinstalled.
Went with just straight purple base coat then cleared them. Turned out great I think, cant really tell there purple unless there in the light right which is what I wanted.
Pics
Does burnouts better lol
VanoFord
Sugarland, Tx
Looks real good. How bout a side pic far away to see them with the whole truck in the pic? I'm interested on how they sit from afar. Thanks bro!
Oh yea purple looks good.
ford rules
No problems at all, ill try and get those pics and vids for you guys. Been super busy lately.
skylinedan
How long center to center on the mount
A you made up for the axle ends ? I see Ballistic has them in 7 8 9 . Gonna get a pair of those and build the rest my self,
ford rules
I would like to answer but i cant make sense of what you typed there... the lower mounts are about 4'' below the axle if thats what your meaning.
skylinedan
Ballistic calls it spread, the distance from the center of the axle to the center of the bolt used too mount the bar to the bracket . You can get a 7,8, or 9 spread, not bad for the money I thought. 32 bucks a piece . I can make my own like you did, just need too get the steel for them. The rest I'm going to make myself, only thing I'm going to do different is not use the ends like yours. Gonna weld a tube cross ways at the ends use poly bushings sleeved for a 9/16 bolt. Picture a pan hard bar only longer.
ford rules
There probably about a 6" spread then, I'd have to measure.
I would highly recommend using a heim at one side atleast your gonna want the adjustability when you install em IMO. Any aftermarket pan hard bar is gonna have adjustability. I built my lower 3 link arms on my ranger like your talking about welded tube and poly bushing then used a 3" Johnny joint on the other side.
skylinedan
Ok, thanks. I was thinking the same thing too about mine, putting a bung in one end so I can adjust it if need be. You can buy Pro comp's that are just a bar with cross ends like I was gonna do, but I do like the idea of being able to adjust them some. I,ve got all the pipe here for the bars thems selves just need to come up with the brackets at the ends. I was gonna buy the Ballistic ones for the axle and make my own for the frame. Just trying to keep the cost down since I,ve got a bunch of other things I,m doing to the truck at the same time, LOL.
I,m thinking if I build a set fro around 200 ish I,ll be happy.
Dan
sniper_101
rural SK
How happy have you been with your design and bar end choices?
I'm thinking about building a very similar setup for mine.
Thanks!
