CKP sensors
fordman2121
huntington, in
What is the reasoning for having 2 ckp sensors and a cam sensor? I assume they have different teeth count on the 2 ckp sensors(anybody know how many teeth) and then witch one is used for rpm?
2wd-fire
the ckp is used for rpm. there is no teeth on the cam sensor just one magnet.
BOSS450
Concord, NC
I have my crank out right now. I will actually be moving the reluctor wheel and can get you a picture. May I ask why you are wondering the teeth count?
fordman2121
huntington, in
Fummins build. Thinking I might be able to use an oe sensor and get a reluctor wheel with the right amount of teeth for the tach. We are using most of the other sensors already so we can use a cts monitor.thanks for looking guys.
fordman2121
huntington, in
I found a pic online of the ckp sensor. Looks like 58 teeth plus 2 missing. Has anybody had a chance to count. So Im planning on making a bracket and mounting the sensor right on it to measure rpm. The wheel we had already is a 58 plus 2 so we should be able to make this work this weekend.
