S400 and S500 compound set up?
Super08Duty
College Station, TX
Any one ever done like an S466 in the valley HP and like an S591 as a LP, or any 400/500 set up's out there for that matter never seen one
Pretty sure Rudy's 6.4 drag truck is running an s400/s500 setup. The problem with compounds that big is exhaust velocity. Can't light a setup that big without spray. One of these days I'll try it.
Cromwell, CT
well i have never personally drove or taken a ride in a truck with a 466 as a single i have heard they spool just about the same as a 366, but as for velocity if u kept the LP exhaust housing slightly tighter AR than normal seems like that would help along with spool i feel too
Super08Duty
College Station, TX
Even with both exhaust housings tight I'm not sure it would want to spool. I could be wrong though. Just assuming.
4.0l sahara
shelton,ct
I would like to see a s467 with something in the in the 95 to 100mm range feeding it or even a s488.
DarkSide2.6
Maryland
I know its a completely different motor but Craig had an S475 and S500 series 104mm compound setup on the cabelas truck. I have an in can vid if you are interested in seeing.
Cromwell, CT
I think Moroni had a s471 and s595 at one point.
i thought so too, I'm interested to see how they liked it and what issues they had with it, cuz it seem like now days we are having no problem spooling 400 series chargers as a single why not start with compounds from there now u know, i mean a 300/400 set up is deff proven its own for sure your the one that did a lot of that for sure with diff set ups
and hell yeah post it up for sure man
Redneck6.0L
Ive run a s366 s595. S371 billet s595. No difference. And a s471 s595. Thats my favorite setup.
Pizza pig
In the Brig (Banned)
MD
king kong made more power with the 66/88 than it did the 75/106, the 88 spools instantly. The s500 made a ton of boost but all it did was creat a load of boost and break stuff.
That's why things are proven and done frequently, because they work.
