Tyler@Street Diesel Performance
Any one ever done like an S466 in the valley HP and like an S591 as a LP, or any 400/500 set up's out there for that matter never seen one
Pretty sure Rudy's 6.4 drag truck is running an s400/s500 setup. The problem with compounds that big is exhaust velocity. Can't light a setup that big without spray. One of these days I'll try it.
well i have never personally drove or taken a ride in a truck with a 466 as a single i have heard they spool just about the same as a 366, but as for velocity if u kept the LP exhaust housing slightly tighter AR than normal seems like that would help along with spool i feel too
Even with both exhaust housings tight I'm not sure it would want to spool. I could be wrong though. Just assuming.
gated properly i believe it wouldn't spool any slower than a 366/488 set up
I would like to see a s467 with something in the in the 95 to 100mm range feeding it or even a s488.
Wont make a difference. Stick to the 66/88, spool faster and air good for 1k plus. Its proven.
Hellen Keller sent this?
didn't Ellerton have a 500 series on the race truck at one point, or currently?
I think Moroni had a s471 and s595 at one point.
I know its a completely different motor but Craig had an S475 and S500 series 104mm compound setup on the cabelas truck. I have an in can vid if you are interested in seeing.
