Track bar for 02
DEEZUZ
NO PUKESTERS
NWI
Now, what exactly do you need it to be adjustable for?
I'm completely ignorant on this stuff
dsberman94
Pennsylvania
I like the ones from Newton lifts and I'm saving up for them now. Newtons completely replaces the rear block with whatever size block you want (for me will be f350 size) then the bar bolts to it. And the block can have bump stops on it just like factory. Plus the bar has a nice thick look to it because it has a large diameter.
ToMang07
Mainah!
Depending on how high your truck is, (Lifted/leveled/stock) the stock bar will pull the axle off-center. (Left or right, depending on the height.) When I leveled my truck, I added 4" to the front, and the axle was ~1.5" off center. The adjustable bar allowed me to center the axle, so it was in the right spot again.
You can see it here if you look close:http://i752.photobucket.com/albums/...dyear Duratracs and 16x10 Wheels/Tires035.jpg
When I got in to adjust the drag link so I could re-center the steering wheel, it looked like this: http://i752.photobucket.com/albums/...racs and 16x10 Wheels/LiftKitInstalled026.jpg
The actual bar: http://i752.photobucket.com/albums/...racs and 16x10 Wheels/LiftKitInstalled009.jpg
DEEZUZ
NO PUKESTERS
NWI
Omg... Is this why I can't keep leaf spring bushings on the left pack for the life of me???
DEEZUZ
NO PUKESTERS
NWI
FYI, I bought the truck as it sits with the lift. The steering box was my first fight against the steering wheel being off and play. Now I have teh wobble and of course my Springs are popping again. First thing I did was replace bushings, now it's bad again.
DEEZUZ
NO PUKESTERS
NWI
I have a 6 inch lift so the zone one won't work, unless they make a bigger one. I remember seeing one that has a shock absorber on it, which ones that?
co04cobra
WV
If you're lifted any then yes that is why. Its putting an uneven torsional load on the bushings by the axle not being center.
The one posted earlier is the same track bar I have to. There are probably better ones out there, but that will get the job done for a lot less money.
ToMang07
Mainah!
It could be. Some kits do an adjustable bar, some just drop the bracket. I like adjustable. PMF had a pretty nice one, but it's 3x the cost.
I had already removed the trac bar when I leveled mine since I had an adjustable one, so I can't say for sure if that would cause it. Do you have steering stabilizer? I installed a cheap dual kit just for peace of mind.
DEEZUZ
NO PUKESTERS
NWI
ToMang07
Mainah!
If I were to guess, I'd say that's a drop bracket with a stock bar. In that case, the Zone one may well work for you.
co04cobra
WV
That is for sure a drop track bar bracket. It works but allows for no fine tuning.
DEEZUZ
NO PUKESTERS
NWI
I'll pick up the zone.
What about a dual stabilizer? I've barely out money into this truck so I guess it'll be ok to drop a bit to get the stability back
co04cobra
WV
Personally, I prefer just one good stabilizer . I haven't found where a dual is a huge improvement. JMO
ToMang07
Mainah!
My thought process was this: If one fails, I still have one. When I'm plowing, LOTS of dirt, salt, and grime coat EVERYTHING, worse than normal winter conditions. So better safe than sorry.
DEEZUZ
NO PUKESTERS
NWI
Another thing was my shocks. As you can see their all pretty much rusted and some leak. But with a spring pack like I have, is there even a reason for shocks? I mean this thing rides rediculousy harsh. I doubt shocks are even doing their job
