Retrofit projector headlights
Steamfighter
Southern Maryland
Sorry guys, not super IPad literate yet. It was around $1500.00 plus shopping to and from. LS 460R projectors , complete. Shipped them on a Monday evening and got them back the next Friday afternoon. Good wide pattern and much better distance than stock. Big thing is no one flashing high beams at you all the time with HIDs. I have more pics, just need to correct the rotation.
Steamfighter
Southern Maryland
Will only post one at a time.
patrick@WDI
One of my buddies sent me these, this is of one of his buddies trucks. Look pretty slick, I believe the upper portion has rigid duallys
Sent from my DROID RAZR using Tapatalk
Powerstroked162
On Da Juice
Wa. State
Just to let you guys know, we will be offering projector retrofits within the month. Prices will be significantly lower than what's been mentioned. So keep us in mind if you're looking to do something in the future.
Carry on
jwlandry
S.W. Louisiana
Carry on
I'd like some info on this if you don't mind Steve. I want some some Harleys that Paul offers with projectors.
patrick@WDI
Cary@ct sells retro shop ones which I should be getting mine in a couple days btw
Powerstroked162
On Da Juice
Wa. State
Pics of lights.
Stay tuned. We will have a pics and pricing by the end of the month.
No sweat. JD is doing a set right now for a friend of mine. 05-07 bucket PTM, retrofit projectors. Should look pretty knarly.
jdgleason
Fort Collins, CO
Also have a 6.4 set in the works. :D
If you guys need anything let me know.
devdiesel
Barrie, Ontario
i just about have the set I'm putting together finished, I'm pretty happy with how they are turning out, i used the 3" fx-r unit and a modified gatling shroud. I had a problem with masking tape lifting some of the chrome which in the end turned out to be a good thing, the buckets are now a combination of a satin silver and chrome (upper bucket matches the lower, painted it yesterday)... should have them finished up this weekend!
neverkickn
AR
I wish I had used the fx-r instead of the mini. I had to modify the bulb base o get the mini to fit and in the process ended up having to epoxy them in place to get them aimed right without the headlight looking crooked.
If I had ground the bulb base right I wouldn't have had that problem but as easy as it was to just epoxy them in, I would definately recommend using the better projector.
Jgon08
Those look good.. I should have mine back next week I'm pretty excited.
