No head pics from him, but he said 6 and 8 were also slapped. I'm suspecting EBP too. Wastegate time.
But why just the driver side and not passenger?
Looks like the valve stamped the piston harder on the outside edge of the piston, hitting at an angle.
you might verify that for sure tomorrow
If the egr was still in place that would explain the left side
but since you dont have a gate its hard to say
do you have any pictures of the bottom of the cylinder head?
Looks to me like there is some melting nea0r that biggest part of the crack, i'm guessing thats where the crack started. I would be putting a new injector in that cylinder for sure.
Looks to me like you also have a back pressure issue, both valves that hit are exhaust valves. generally tho exhaust valves hit first, so it could be a combo of overspeed and back pressure.
Are you saying that the EGR delete will cause over speed and too much EBP which leads to the valve float and slap I'm lost here.
Injector was replaced on the affected cylinder
how long ago?
Wonder if they switched the heads when they put it back together and this .is the reman head side? If it was machined below spec valves may hit and piston may of hit head. The clean ring on the piston looks like the machine marks have been 'flattened' slightly. Need pics of head.
