Powersmoke_sd
I was wonder if anyone has done this swap? Stock or lifted would be cool to see.
Any of you guys out there running a 99-04 SD with an 05+axle swap, did the new suspension setup add any height over what you had with the leaf spring setup? Stock for stock, 6"-6"
I'm wanting to run 35's if I do the swap so I'd like to know how much lift I will need to make that happen.
Thanks
Thanks
