After 316,000 miles, I think my truck finally needs the hpop. With the scan gauge, it would only read 250-400 icp. I unplugged the icp sensor and it shoots to 1573, and still does not start. Other than the hpop, what else could it be?
Maybe he just meant intake, vc's, turbo, etc.Yea but. Hard to dio when things are torn apart. Wait for tool so you have a direction
^whs. I just had one that would die when warm, would read 15psi icp. When cold, I got about 300. He **** an injector top I ring out... Air test would be your friend here.
Sent from my VS988 using Tapatalk
Lol, yeah. He said he made it home ok. Thanks for the business buddyI’ve got a feeling I know what truck this was.
Some air leaking from around the top of the injectors is normal when they are dry. It takes some oil to get a good seal. Get the pump in, fire it and drive the **** outta it. The let it sit for 10-15 minutes and see if it restarts.Well, got injectors and stand pipe with dummy plugs on passenger side in. Still didn’t put hpop in, but pressured up through the branch tubes. Still leaks. Used nothing but ford parts. I can’t tell for sure, but it seems like the leak is coming from the nipple orings. Other than the injectors, dummy plugs and standpipe, or the rail itself, where could it be coming from? I hope it’s not the branch tube itself. The nipples had a little slack, but weren’t very loose at all.
