100+ PSI fuel pressure
Twan
Berthoud, Co
If the gauge is on the regulator then it has been regulated, so your not getting a reading of the pressure before the regulator.
Twan
Berthoud, Co
Easy, it's a regulated return. Key word being return, now who has checked there pressure before the heads and before the regulator? I'm betting no one has.
I'm not trying to be a ass, so let some people test this and see what happens.
If someone want to call and we talk, work out a price for parts, I will pay the parts cost if I'm wrong.
Pizza pig
MD
The stock system is a regulated return, it regulates the fuel needed to send to the injectors and returns the rest before sending it to the injectors. A "regulated return" just does this after the injectors so there is always the proper amount of fuel in the rails. The fuel supply BEFORE the regulator should be what the regulator is set at, not after, like stated before these are bypass regulators.
alwil
Saskachetoon
I would bet Twan is right.
They dont make an upstream regulator, thats why in every instance where a regulator is needed it is before the low pressure part not after it.
09stroker
Texas
So your saying every regulated return is running 100+ psi (well really could be any number since it's not at all regulated) to the injectors?
Why on earth would you want to only regulate the fuel you are dumping back to the tank?
alwil
Saskachetoon
So he should take his readings off of his y block at the front of the heads?
Twan
Berthoud, Co
You can't regulate fuel before the regulator. For $100 you can check this. Like I said I will pay the parts if I'm wrong. Just call and will talk.
09stroker
Texas
If the entire system was sized properly and allowed full pump flow to the regulator so it can do it's job it wouldn't matter if it was checked at the regulator or the y block. But, if there is a restriction somewhere between the pump and regulator that restriction would cause the pressure to rise between it and the pump.
Twan
Berthoud, Co
Each pump has it's own psi set, some you can adjust on the pump, others can't.
Test it. You'll see.
alwil
Saskachetoon
So your saying every regulated return is running 100+ psi (well really could be any number since it's not at all regulated) to the injectors?Only in cases where the pump can push that much fuel
You dont.....but the pump only knows one speed and its going to pump as fast as it can untill something is put in there to slow it down.
I think his regulator is bypassing fuel before his truck is running and thats why he is getting a lower reading at the regulator before startup.
09stroker
Texas
Have you seen how elite sets up their 6.4 fuel system? It doesn't even go through the regulator, it just tees of the line coming from the lift pump to the HPFP.
kyle43335
if the regulator gauge port was on the return side(bottom port),the gauge would read zero.
you cant have pressure without restriction for the pump to push against.
that is what the regulator does. it provides a adjustable means to control pressure.
and when you increase pressure,you decrease flow. they dont rise and fall together.
SICKS LITER
Salem, NH
the stock banjos and stock hardlines on the back of the heads are a major restriction.
i would run -10 (5/8s) from the pump to the engine then split it to -6 going in and out of each head to the regulator.
kyle43335
with atleast a -6 return line. if not ideally -8
2wd-fire
this is 100% correct
