16" Dually Wheels
semperfidooordie
Fairbanks, AK
Will they fit on an 08 DRW truck? I would like to run them if possible as I prefer 16s to the stock 17s but wasn't sure if the 16s would clear the brakes.
8inchstroker
AZ
I was under the impression they wouldn't clear brakes,maybe with some spacers? Hopefully someone will chime in that knows for sure.
drunk fingered from DROIDX
fordfreak4life
Different bolt pattern 05 to current are 8x200 and 99-04 are 8x170 anything older is 8x6.5.... Hope that helped out
sent from my mf'n droid
semperfidooordie
Fairbanks, AK
I realize the lug difference I was just curious because I'm old school and like Interco tires...wanted to run the TSL Radials but they only come in 16s and down. I was thinking of running a camo rockstar wheel in 16 if it would clear.
WeBeStrokin
Mifflinburg, PA
Not sure on your state laws either but you may not be able to drop rim size since it was a factory 17". So if I was you I would check the state and local laws first on that as well.
WeBeStrokin
Mifflinburg, PA
Just thought I would throw it out there cause I would hate to see you spend the money on them and then you lose your ass on the whole thing. I mean it might not be an issue but it would be worth checking into first.
semperfidooordie
Fairbanks, AK
Definitely a good point and I appreciate it man. I'd much rather err on the side of caution then get my balls busted over something I never would have thought of lol
