190cc with 66mm...which one?
Mdub707
Mohawk NY
I dyno'd my 06 on a loaded superflow before and it always reads high. I did the numbers in my sig... 466/772 with just an x-race tune and 100% bone stock everything else, including air filter and exhaust with the cat and muffler in place. 1/4 mile calculator put me at 423 rwhp though.
Pizza pig
MD
you can make a 66 not laggy, its just expensive to do it. Either way 64/71/70 will be a great turbo, Im considering one as wel, but im seeing what the next 6 months brings technology wise :evil come one bullseye
MorganY
college station, tx
I just dont want another mechanical part like a diverter valve..if thats what you were referring too. Im already going to gate it if i spray :)
MorganY
college station, tx
So im looking on bullseyes website for a 64, and they dont have a 64/71/70...nor do they offer a billet wheel...what now?
Pizza pig
MD
I've learned to not go by the Bullseye website, they offer WAY more than what the site states.
Call Bill or e-mail him and tell him what you want.
for reference he quoted me $1650 for a 62/68/70 gated w/ batmowheel
They dont make 64mm batmowheel, yet at least. but it doesnt matter, their 62 bat flows like a 64 and the 66 flows like a 72.
The diverter valves are awesome, its well worth the money, adding another mechanical part on a 6.0? haha that made me laugh dude, its a great product.
bullseye :demon:
strokin6L
Springville NY
bullseye :demon:
i did hear of a couple already having some problems with the diverter not working correctly or seizing up....so idk
Pizza pig
MD
i've heard of a few too, but thats just how the world goes round... nothings perfect :pint:
Pizza pig
MD
my guess is if it was stuck open you would notice lag, and if it were stuck shut, you would notice a big increase in drive pressures
MorganY
college station, tx
I have been hearing alot about drive pressures..where do you place the sending unit for a drive pressure gauge..does ISSPRO make one? or is it like a boost gauge? like I said earlier im new to turbo stuff
strokin6L
Springville NY
drive pressure is the exhaust pressure that drives the turbo. All you really gotta do is pull the EBP sensor out and install a T fitting and put the EBP sensor back into the one end of the T fitting and run a coiled line from the other end of the T fitting to where ever and install the boost into that.
strokin6L
Springville NY
Here's a pic of what i did. If you need more pics let me know.
MorganY
college station, tx
If you have more pics that'd be great, so basically I tap into the EBP tube and run the line into a boost source then into a regular boost gauge? Im going to give it a shot on explaining this, so ideally im looking for 1 to 1 ratio. I basically join a boost line and EBP line into a boost gauge. If my boost gauge showing only boost, is reading 20psi, and my EBP and boost combo gauge is reading 10psi, that means I have a net increase of 10 pounds of backpressure? (30psi of drivepressure) sorry if I am way off here, I want to run a drive pressure gauge for when I use nitrous
strokin6L
Springville NY
i'll get more pics. One boost gauge will be reading actual manifold boost...where as the other boost gauge will be for drive pressure reading. If you have 10lbs of boost and 10lbs of drive pressure....then ratio is a 1:1.
MorganY
college station, tx
okay, i think i got the jist of it! what is a ratio to start backing off, like 20+lbs of backpressure (1:2)?
MorganY
college station, tx
okay thanks, whats a good ratio to start backing off, mainly for when I tap into my 10lb bottle sitting in my kitchen :p looks like i'm going to add some gauges near my rear view mirror soon. boost, EBP, and an HPOP gauge i guess....
