Black04Ram
Need a quote on a Oil cooler, engine cover bracket with the two nuts, passenger side valve cover, and driver side front door handle (just the standard black). For a 2002 f350 7.3, and shipped to 77354
sunrisefordparts
on the oil cooler your looking for the seals and the cooler unit? also on the engine cover bracket is yours the stamped steel bracket or the cast bracket?
sunrisefordparts
both upper and lower
and some silicon RTV I think its called as well for the oil pans, plus for the front and rear diff covers im replacing
pump list $253.50 sell $182.52 w/exchange (core $60)
upper pan list $388.46 sell $303.00
lower pan list $94.48
bolts (for lower pan) list $1.39 sell $0.83 each x15
silicone for pan list $23.08 sell $16.62
silicone for the diffs list $26.05 sell $18.76
shipping $40 due to the size and weight of the upper oil pan.
q#455444
screwcab
I am looking for a few interior parts as I am color changing the interior of my truck. I am looking for the ebony kick panels and an ebony rear seat belt opening cover. I am looking for the following:
6C3Z-2502345-AAA
6C3Z-2502344-AAA or 2C3Z-2502344-AAB
3C3Z-2660230-AAA or 5C3Z-2660230-AAA or 7C3Z-2660230-CA
Could you please let me know if the parts are available and pricing. Thank you for your time.
sunrisefordparts
6C3Z-2502345-AAA
what year is your truck, possibly your vin and I can go from there for the parts look up to make sure it fits your interior just in black.
screwcab
The truck is an early 99 F350 CCSB. It was originally a Prairie tan interior truck. I am in the process of changing most of the truck to ebony trim. I have been using 05-07 Harley-Davidson part numbers as these parts fit the truck. I found the above part numbers through Ford part sites and am hoping they may still be available.
sunrisefordparts
6C3Z-2502345-AAA
well some bad news, the part #s 6c3z-2502345-aaa, 6c3z-2502344-aaa, and 2c3z-2502344-aab are obsolete from ford. there is an earlier production part for the drivers side is #4c3z-2502345-aab that is still available. as for the seat belt opening bezel the 5c3z-2660230-aaa is a tan colored one and the 7c3z-2660230-ca is for the 08-10 trucks.
4C3Z-2502345-AAB list $40.13 sell $28.90
3C3Z-2550230-AAA list $6.92 each sell $4.98 each
q#455767
ncollins64
winchester springs, tn
Doing a stud job on an 08 6.4.
Vin-1FTSW21R18EC17555
Need pair of intake gaskets
Head gaskets
Oil cooler kit
Rocker box gaskets
Valve cover gaskets
Hpfp cover gaskets
And anything else you can think of. I'm not sure what the guy already has. Thanks
sunrisefordparts
Head gaskets
Oil cooler kit
Rocker box gaskets
Valve cover gaskets
Hpfp cover gaskets
heres the quote, I added in the turbo mounting kit and exhaust manifold gaskets if needed. also the head gasket kits from for come with head bolts.
  • Q456224.pdf
sunrisefordparts
Thanks. Can I also get a price on the updated hpfp harness kit and also all the high pressure fuel lines. And also all of the ex manifold hardware bolts.
the high pressure gasket/harness kit with the 2 feed lines is already on the quote, I added the manifold hardware and the line kits to the injectors.
  • Q456224.pdf
looking for OEM remote start kit (with small square fobs) for 2012 F350 XLT diesel
VIN for reference is CEB02314
sunrisefordparts
looks to be a few parts to make up the kit for the remote start.
module list $198.57 sell $166.80
remote list $41.43 sell $34.80
antenna list $62.86 sell $52.80
q#456341
free shipping
