sunrisefordparts
Could I get a quote for these:
F57Z-78022A68-A
F57Z-78022A69-A
Only need the passenger side, but might be mis-matched with the age.
Also, do they come with the nozzles already installed in them?
Thank you.
F57Z-78022A68-A list $83.58 sell $60.18
F57Z-78022A69-A list $83.83 sell $60.36
washer jets don't come with the cowl from what I can see.
washer jets list $10.88 each sell $7.84 each
q#513176
sunrisefordparts
2005 Ford Excursion Limited 6.0 4x4
Need pricing for Front and Rear bump stops and the snubber spring stops.
I’d also like pricing on the 30mm rear sway bar along with axle mounts and the excursion end links for the bar. If I remember right, the 30mm bar is off a f350.
Can PM if you like.
Shipped to 31831
Thanks
Jason
heres the quote for the bump stops and the sway bar, the end links as well as ubolts for the sway bar brackets are obsolete.
  • Q513174.pdf
sunrisefordparts
What’s the alternative for endlinks and u-bolts? Will ones from another truck like a f250 work?
if they are the same part number they will be obsolete as well, I think the truck ones are longer for the sway bar links. another option would be aftermarket for those.
PSD POWER007
Columbus, GA
Yeah, looks like the Hellwig bar is the easier and likely cheaper route. Wasn’t the case a few years back when I put the 30mm bar on my 2003 Excursion.
David N
Eastern NC
F81Z4851AB. I think thats the yoke for a 2002 F250 with a 7.3 Liter. If it is, I need a price shipped to 27892. Thanks!
tigwerks
Considering freshing up the truck with some new door panels, I believe these are the correct part #'s for a lariat with the black/charcoal door panels.
shipped to 89701, thank you.
7C3Z-2523942-CE
8C3Z-2523943-CE
7C3Z-2627406-FB
7C3Z-2627407-FB
