sunrisefordparts
Can you give me a quote for bc3z-14a005-aca ? I'm trying to make sure this is the right body harness for a 2011 F-350 Crewcab lariat with Memory drivers seat, Heated/cooled seats, sunroof, power sliding rear window with no rear defrost Vin Number 1FT8W3BTXBEB29010
BC3Z14A005ACA does show to be correct as per your VIN,
List price $759.58 -- your cost $546.90 + shipping
quote 558965
thanks,
Sean
jschildm
Southeast Iowa
Could I get a price on a 4 wheel drive actuator for a 2014 F-150? The part between the wheel hub and the axle shaft. I think the part number might be 7L1Z3C247A.
Thanks.
sunrisefordparts
Thanks.
List price is $166.33 -- your cost would be $119.76 + shipping
quote# 560036
thanks,
Sean
sunrisefordparts
Truck is a 04 F250 6.0
15 qt 10w30 diesel oil motorcraft
Oil filter
Fuel filter
Air filter
Oil filter cap
unfortunately we can't ship fluids, here are prices on everything else...
Oil filter - List $32.11 - your price $21.19
Fuel filter - List $83.62 - your price $55.19
Air filter - List $86.36 - your price $57.00
Oil filter cap - List $34.93 - your price $23.05
+ shipping
thanks,
Sean
Quote-561129
Ad8 PRODIGY
Orange County, NY
Lower fuel filter on the frame, I need two of the plastic bases that spin up onto the filter base with the filter inside them. Don't need the filters, just the bases..
Also maybe a driver side front door Twitter? Mine seems to be a little bit blown and I'm curious how much it is for a new one
Are you able to get any bed rail trim? Truck is a 2014 King Ranch with the tan Plastics on the top of the bed. Missing two of the stake pocket plugs and the entire Front plastic trim piece under the back window
Sent from my SM-G955U using Tapatalk
sunrisefordparts
Hi,
-the Fuel filter caps list for $32.74ea, your price would be $18.47 each
-the speakers list for $34.79, your price is $29.22 each
+ shipping
-as far as the bed rails, I would need to know if you have the 6ft or 8ft bed,
but chances are the 8 footer would be too expensive to ship. I can however get the stake pocket plugs separate... they are $6.07 each your price. ($8.43 list)]
there is no bed trim on the front of the bed
thanks,
Sean
Q562052
Spectre32
Need a price on Tie Rods Left/Right Outer and a Right outer with a stud for the Draglink.
2008 F250 HD; 4x4, Diesel, AT.
Thanks!
sunrisefordparts
Thanks!
RH outer - List $182.53 - your price $120.47
LH outer - List $180.07 -- your price $118.85
drag link outer - List $73.60 -- your price $48.58
+ shippping
thanks,
Sean
Quote#562414
Motostroker
Here is a picture of my vin:
Long story short. I’m removing the fass fuel system off my truck.
-I need a complete new sending unit (entire apparatus that drops into tank.)
-supply and return lines from sending unit to LPFP
-complete LPFP assembly and bracket that attaches it to frame along with hardware
Thank you
Sent from my iPhone using Tapatalk Pro
sunrisefordparts
Thank you
sending unit- List $472.25 -- sell $311.69
sending unit gasket- List $7.31 - - sell $4.82
fuel lines- List $379.33 - - sell $273.12
LPFP- List $678.36 - - sell $447.72
LPFP bracket (includes studs) List $75.55 -- sell $42.61
+ shipping.... the shipping on the fuel lines will probably be more than the savings due to the size...
thanks,
Sean
Quote-562532
Danny26
Idaho
Quote on
2017 F350
-Paintable mirror caps
-Black tow hooks
-Paintable door handles
-Black bottom window trim on doors (to replace chrome ones).
Thanks!
sunrisefordparts
Quote on
2017 F350
-Black tow hooks
Thanks!
Hi,
Can I get the last 8 digits of your vin to determine what is on the truck now
thanks,
Sean
sunrisefordparts
Quote on
2017 F350
-Black tow hooks
Thanks!
-Paintable mirror caps - List $9.62 -- your price $6.92 each
-Black tow hooks - List $66.05 -- your price $47.56 each
-Paintable door handles (front) - List $122.17 -- your price $87.96 each
-Paintable door handles (rear) - List $77.05 -- your price $55.48 each
-Black bottom window trim (front) - List $85.33 -- your price $61.44 each
-Black bottom window trim (rear) - List $70378 -- your price $50.96 each
total = $620.64
+ shipping....
thanks,
Sean
quote #562959
Illinois
Hi Sean,
Can you still get 1st line (blue box) pads and rotors? 2010 f250 srw. Vin# AEA85033.
Thanks,
Pete
