buckeye7048
APIM for a 19 f150 to add nav to our xlt with the factory 8” touch screen.
Thanks,
George
sunrisefordparts
Thanks,
George
Hi George,
I can only get APIMs on a per VIN / exchange basis, I have no way of ordering an upgraded unit....
sorry,
Sean
Justinlw
Hi, looking for a couple things for a 2010 F250 6.4l:
Rear Bump Stops Right and Left
Large hose from Fuel Fill Neck to Tank
Front Lower Coil Spring Perch Bolts
sunrisefordparts
Can I get the last 8 digits of your vin please
thanks,
Sean
sunrisefordparts
AEB02377
Rear Bump Stops Right and Left: List $49.82 -- your cost $34.37 each
Large hose from Fuel Fill Neck to Tank(serviced with filler neck assy only)
:List $262.72 -- your cost $173.39
Front Lower Coil Spring Perch Bolts (serviced with lower spring mount only)
: List $57.77 -- your cost $39.86
thanks,
Sean
q589314
longstroker42
vin- 1FT8x3BT4BEC09402
can i get a price on both left and right cylinder heads, primary water pump, secondary water pump, fuel injector return line, serpentine belt and rear blocks with ubolts
[email protected]
sunrisefordparts
Hi,
The heads are updated, they are going to require different glow plugs. I went ahead and added the glow plugs as well as head gaskets and head bolts to the ticket as well as nuts for the Ubolts...
quote 590001 is attached (shipping will be extra)
thanks,
Sean
  • Q590001.pdf
