sunrisefordparts
Need a 3 bar MAP for 2015 explorer p/n AA5Z-9F479-D, and a passenger seat belt for 07 mustang gt black thanks!
Hi,
AA5Z-9F479-D: list $131.87 -- your cost $79.78 + shipping
For the seatbelt, can I get the last 8 digits of the vin please?
thanks,
Sean
Sterling B.
Bryan, TX
I need a price on the rear stone deflectors for a 2001 Excursion. Going to be removing the cladding from a Limited... I think the PNs are YC3Z-78292A23-AAA for the left and YC3Z-78292A22-AAA for the right.
Are these the only items needed after removing the Limited trim cladding?
Also needing the cigarette lighter for the same vehicle; the tangs are broken that hold it into the lower dash.
All shipped to Bryan, TX 77801
sunrisefordparts
Hi,
I am not sure what else you may need to remove the cladding, but the numbers you gave me do show to fit the XLT version....
YC3Z-78292A23-AAA: List $19.72 -- your cost $13.60
YC3Z-78292A22-AAA: List $19.90 -- your cost $13.73
lighter socket: List $11.59 -- your cost $9.33
lighter retaining ring: List $11.66 -- your cost $9.38
shipping: $16.65
Q625856
thanks,
Sean
Sterling B.
Bryan, TX
Hi,
shipping: $16.65
Q625856
thanks,
Sean
Thank you! forgot to ask... are the deflectors grey/black?
Sterling B.
Bryan, TX
Hi,
shipping: $16.65
Q625856
thanks,
Sean
I also need to add an AC fan speed control switch and fan speed resistor for a 2000 F250 VIN: 1FTNX21F4YEA91790 to this quote. Just want to try and get everything I need right away if at all possible; thank you for your help!
sunrisefordparts
Hi,
Switch: List $41.98 -- your cost $26.55
resistor: List $23.40 -- your cost $14.80
thanks,
Sean
ford_trck
Vail, AZ
I need a quote for the front seatbelt bolts that go into the floor. A shouldered Torx head M12 bolt.
Also the drivers front seatbelt in tan.
Early 99 F-350 Crew Cab.
Also can carpet still be ordered for it? It is a 6 speed manual with electric transfer case.
sunrisefordparts
Hi,
bad news all around, the Torx bolt is only serviced with the seatbelt assembly which has been discontinued. I tried the locator and there aren't any tan ones anywhere... there are two dealers still showing to have a grey one.
The carpet is also discontinued, no luck on the locator in any color...
sorry,
Sean
sunrisefordparts
How much for a fuel pump for an 08 gt mustang
Hi,
List price $392.02 -- your cost $237.17 + shipping
it is currently on backorder with no ETA... There are a few dealers showing stock on the locator, but the price would go up a little depending on how much they charge me....
thanks,
Sean
Q627605
O.B.S 7.3
Atchison Kansas
17 platinum interior harness
Im look for a interior wiring harness so I can fab my 17 f250 platinum seats into my obs and make the massagers work. What does one run!?:bowfast:
sunrisefordparts
I dont think I will be able to help on this one, the harness that plugs into the seat shows to be part of the whole body loom, would need the vin from the donor truck and even then I am not sure it would work....
Sorry,
Sean
TFDWookie
Gilbert, AZ
Sean,
Wanted to check in and see the status of a wiring harness from a order I placed in July. The order number was 1634.
Thanks
Kris
