MorganM
SE Houston
Top pad- BC3Z-17C829-BA
R/L Outer molding- BC3Z-17K832-CA and BC3Z-17K833-CA
R/L Bezel- BC3Z-15A245-AA and BC3Z-15A246-AA
Shipped to 77573
Is pricing the same if I order myself from the website?
Iso-baric
Sonoran Desert
2008 F250/F350 Lower instrument panel. With auto trans. Stone.
Part # 8C3Z-2504608-ND
Motorcraft Full Synthetic Manual Transmission Fluid - XT-M5-QS - 9 quarts
Thanks.
okstatehuck
Looking to retrofit 2015 Turbo to 2012 F250. I think the parts below is what is needed. Shipped to 73078.
C3Z6K682A – Turbo
FC3Z9T514A – Gasket Kit
FC3Z6N639A – Pedestal
FC3Z9G437B – Exhaust Pipe (Right)
FC3Z9G437C – Exhaust Pipe (Left)
FC3Z6N646C – Down Pipe
FC3Z8287A – Pipe Clamp
FC3Z9B613A – Inlet Hose
FC3Z6B689A – Oil Tube
FC3Z9U469A – Water Outlet tube
FC3Z9430B – Manifold (Right)
FC3Z9424A – Inlet Manifold Assembly
FC3Z9448A – Gasket (Right)
FC3Z9448A – Gasket (Left)
FC3Z9A462A – Heat Shield
FC3Z9E464A – Gasket
FC3Z6N646A – Exhaust Pipe
BC3Z-8527-N - O Ring Heater Core Line
Thanks
sunrisefordparts
Shipped to 77573
Hi,
BC3Z-17C829-BA: $38.20
BC3Z-17K832-CA: $22.00
BC3Z-17K833-CA: $21.81
BC3Z-15A245-AA: $20.56
BC3Z-15A246-AA: $14.85
Shipped to 77573: $24.82
The price on our website is close, but sometimes I am able to get a little more off for you guys...
thanks,
Sean
Q630712
sunrisefordparts
Looking for 7.3 engine mounts. 94-97.
F7TZ-6038-CA
F5TZ-6038-C
I believe those are correct
Shipped to 15701 or 15717
Hi,
They have been discontinued, but there are still some on our parts locator...
F7TZ-6038-CA: $56.48
F5TZ-6038-C: $66.90
shipping: $17.94
thanks,
Sean
Q630716
sunrisefordparts
C3Z6K682A – Turbo
FC3Z9E464A – Gasket
Thanks
Hi,
The turbo has changed numbers and requires a different pedestal, coolant tube, gasket, filter and gasket kit...
HC3Z*6K682*A: $1441.17 + $250 core
HC3Z*6N639*A: $65.99
FC3Z*9U469*B: $26.91
HC3Z*6587*A: $4.25
HC3Z*6C683*A: $2.12
HC3Z*9T514*A: $60.39
FC3Z*9G437*C: $77.75
HC3Z*9G437*A: $105.91
FC3Z*6N646*A: $148.20
FC3Z*8287*A: $10.47
FC3Z*9B613*A: $19.00
FC3Z*9U469*A: $26.38
FC3Z*9430*B: $ 68.00
FC3Z*9424*A: $118.43
FC3Z*9448*A: $19.35
FC3Z*9448*A: $19.35
FC3Z*9A462*A: $15.69
HC3Z*9E464*A: $11.37
FC3Z*6N646*A:$ 148.20
BC3Z*8527*N: $14.07
total: $2653.00 + shipping
For the shipping I would guestimate $175 hard to figure with such a large order...
thanks,
Sean
Q630747
sunrisefordparts
Can you get the passenger side spring bucket/shock mount for a 2000 F350 2 wheel drive? Along with a set of springs.
Hi,
spring bucket: List $87.55 -- your cost $57.78 + shipping
for the springs I will need the vin number and or spring code off of the certification label.
thanks,
Sean
