swinky
Awewsome man. Hopefully I'll get home soon and we can make some passes.
I just made 680 rwhp with 1427 tq
I aslo have 3 bad injectors lol found after the fact
I have the 467 fmw with dual pumps
If all works out over the next week I'll be swapping out my 13 pump for a 15 and still keep the H&S Dual Fuel pump. I'm not gaining only a few HP going over 2300us and if the 15 pump alone does 647 this should easily be able to push me across 700 wheel HP.
a stock 11-14 cp4.2 and cp3 will make over 1000 .
Discussing you and I have had before anything over 2200 made no difference in HP with stock injectors.
And if that is not enough, we have brand new Bosch 10mm stroker pumps that are 30% over you can change out for the stock one in our kit as well![]()
Hit Mike up, I believe he has some in stock........
http://hs-motorsports.com/fueling/07-14-cummins-6-7l-10mm-stroker-cp3-pump.html
A 15 pump is about 1000 bucks slides right in but they are currently on back order til mid april
At more than 2.5x the price.![]()
Not to derail your thread but I've been talking to Tadd about a 3794 w/68 mm billet wheel. He says spoolup should be simuliar with about 60 additional horses....What are your thoughts?? This should put me high in the 600s....
Sorry Gary I just can't sign off on that one. I would much rather you go with one of his Precision setups if you want to go to 600+. We tried every Tune out there with the 3794 and the 4094 and it was rough. Go with the non-VGT and Tadd knows how to Tune your truck. Tell him to send you Tune DS106 it's life changing after the 3794. Sell that 3794 to the 6.6 Duramax guys you will get all your money back and you'll be happy. Sure that's not what you want to here but I'll give it to you straight from experience.
it not the injectors. They flow more than a 6.4 on the flow bench. The pcm is limiting fueling... Not the injector. There is 700 available if you can get it to fuel. I have yet to drop rail with dual fuelers.Discussing you and I have had before anything over 2200 made no difference in HP with stock injectors.
its NOT from a lack of fuel .
around 700 is the limit on stock injectors
The 15 pumps are a good upgrade yes, but in my opinion for the ease of install, and future upgrade's, the dual fuel kit is still the way to go...........
and 2.5x the potential![]()
