20x10" -24mm wheels and lifts
mattmal9
Severn, Maryland
I havent either really on the 11-14, that's kind of why i'm interested in trying it, plus i like the wide stance looks aggressive. Just trying to see what i may need to do to make it work.
mattmal9
Severn, Maryland
And the wheel poke
is that the wheel poke after being leveled and the rear lifted some?
mattmal9
Severn, Maryland
That's factory height with the leveling kit the front shifted slightly to the right. Not much about an inch.
with leveling your truck the way you have, im going with a 3 inch level and was thinking about 20x12 -44 and 33's. Do you see any problems with that combination rubbing bad?
SD6.7
Awesome pics and good info thank you! Nice truck!
What track bars are you running? Can you show pic of trimmed pinch weld and liner please?
Nj67
South NJ
When I had a 2 inch it rubbed slightly so I did the readylift 3.5 and it doesn't rub at all. uploadfromtaptalk1393801325849.jpguploadfromtaptalk1393801355490.jpg
First pic is 3.5 and bottom is 2 inch
