rhorsers
How much for the 05-07 Ford grill Emblem?
Sent from my SM-G955U using Tapatalk
2017 F150 Access Cover Screws for Tailgate (short ones). Ditching the plastic liner and getting a spray in and the current screws are too long and have a black washer on them. I need 8 of the shorter screws that come with the trucks without the plastic liner. Also 1 of the snap anchors in the tailgate had a screw snapped off in it so I will need 1 of the anchors to replace it as well.
Sent from my Galaxy S7
Paypal sent. Thanks!screws: List $1.06 Sell .64ea
anchor: List $1.34 Sell .80
shipping $3 (total $8.92)
Quote 528949
2006 f250 6.0
blue spring
hpop
head gasket left and right
rocker cradle gaskets?
water pump
stand pipes left and right and if it is in a kit with dummies, then that as well.
injector oring kit x8
intake manifold gasket x2
up pipe that flexes on the back of the turbo that connects the left and right up pipe from the manifold
ipr solenoid
long list
thanks,
jarrod
2012 f250 6.7 4wd
looking to replace on front axle both sides; u-joints, upper and lower ball joints and 4wd locking hubs and any associated parts to do such.
also the u-joints from both drive shafts
and tail gate plastic top edge piece, non step tail gate.
thank you
brian
can I get the last 8 digits of your vin
thanks,
Sean
2012 f250 6.7 4wd
thank you
brian
engine heads. idk if they are the same or a left and right.
18mm
2006 6.0
thanks
also what do yall do about the cores or how do you process them?
Sean,
Can i get a price quote for the following: 3C3Z-6C755-AA Its for an 2008 F250 6.4.
Thanks!
hpop
icp sensor on pass valve cover
degas bottle
degas bottle cap
the y hose under the degas bottle
upper radiator hose
upper and lower cab bushing with bolts under the radiator
oil cooler
front and rear axle bumper stops
radiator
driver door window switch
blue spring kit for fuel
2006 f250 6.0L Crew Cab fx4
thanks
