25% discount on ford parts to members
kleake
Sapulpa, OK
unfortunately the clutch is not serviced separately from the compressor....
compressor: List $634.31 -- your cost $383.76
+ shipping
thanks,
Sean
q582271
Help me understand, I can buy A/C clutches all day long for under $40 (example: https://www.autozone.com/cooling-he.../a-c-clutch-and-components?filters=4294748565) but NOT for a 2011 explorer? The only way to get it is to buy the entire compressor? So a $40 part on most cars is going to cost me $400 plus freon evac and service because I have to buy a compressor that I don't need???
Please look at this Ford dealer site (https://parts.lakelandford.com/p/Fo...C-Compressor-Clutch/54210970/EB5Z19D786A.html), it states I should be able to replace the clutch only. Although, Amazon has a compressor and clutch for $230, this isn't much cheaper. Please see if I can get something cheaper than $400...
sunrisefordparts
Hi,
The clutch Lakeland has listed shows to fit 2013-19 Explorer in my catalog.... However the compressor assembly shows to be the same 2011-15, so in theory it should be the same clutch....
your cost on it from us would be $179.04 + shipping
let me know if you want to give it a shot....
thanks,
Sean
kleake
Sapulpa, OK
I'll give it a shot for sure. Amazon has that P/N for $140, free shipping, Rock auto has it for $156 plus shipping and both are Motorcraft brand. If you can match their price I would rather get it from you.
Kenneth
sunrisefordparts
Kenneth
Not sure how they do it, but $156 is less than I pay for it from Ford.... sorry
Jarrod B
Corpus Christi Texas
2014 f250. The aux relays for aux 1 2 3 4.
Part numbers I have is 9L2Z 14N089 and 5C3Z 14N089.
Like a big and little relay. Idk if my part numbers are updated or accurate.
Thanks
Jarrod
Sent from my SM-G965U using Tapatalk
sunrisefordparts
Thanks
Jarrod
9L2Z-14N089-A : List $24.62-- your cost $16.99
5C3Z-14N089-A : List $32.62-- your cost $22.51
+ shipping
thanks,
Sean
kleake
Sapulpa, OK
2011 Explorer Limited AWD
Left driver door latch (you can lock door, everything moves and works properly, but it doesn't actually lock the door)
Strut tower bearings
Front brake pads & rotors
sunrisefordparts
Can I get the last 8 digits of the vin, there are two different latches....
thanks,
Sean
sunrisefordparts
Left driver door latch: List $117.87 -- your cost $78.98
Strut tower bearings: List $64.73 -- your cost $40.94 each
Front brake pads: OE- List $90.69 -- your cost $57.36
Value line- List $60.00 -- your cost $37.95
Front rotors: List $119.78 -- your cost $73.79 each
+ shipping
thanks,
Sean
Q586218
kleake
Sapulpa, OK
+ shipping
thanks,
Sean
Q586218
Thank you, I will be in touch once I narrow down what I need.
Sent from my SM-G960U1 using Tapatalk
Jake
TEXAS
2015 F350 need transmission switch assembly. I guess the switch is part of the transmission controller inside the case.
Sent from my XT1650 using Tapatalk
