25% discount on ford parts to members
Shootingstar
NE OK
Can I get a price for the mounting brackets for the center console for a 08 F350 crew cab. I have the center jump seat and I'm wanting to install the console I picked up
kdsf350
Oregon
2008 F350 Lariat Headlight switch & knob with auto/fog lights, and one plastic bezal cover retainer clip broke when pulling off to access switch. Shipped to 97045. Thanks
sunrisefordparts
front bracket list $75.90 sell $56.92
rear bracket list $93.60 sell $70.20
quote # 264321
sunrisefordparts
Need a quote for a, 1997 drivers side mirror head for the 2 post mount, shipped to 21048.
not sure what style mirror you have. those years ford offerd the mirror that mounted on door with triangle bracket, and mirrors that mounted with arm at top of window and bottom of window like you see on most big rigs
sunrisefordparts
No just the filter. have a 2006 f350 and i am going to add the 08 pan and filter on the transmission and change fluid and the bypass filter
the 08 filter list $75.67 sell $44.27
08 pan list $84.32 sell $63.24
the 6.0 style external filter list $44.71 sell $26.16
fluid should be lv fluid in the torqshift trans
list $6.49 each sell $5.36 each
sunrisefordparts
h/l switch list $49.51 sell $31.32
clips sold with panel only list $123.58 sell $92.68
quote # 264324
HaysKSFirefighter
Valley Center, KS
Need to get the hub lockout gasket and o-ring kit, and the knuckle to hub o-ring, as well as the dust seals for both sides of a 07 f350 dually front axle. I fubard' my half shaft u-joints the other night and need all the seals I have to replace when I tear it apart.
sunrisefordparts
hub rebuild kit list $33.07 sell $24.80
hub seal list $9.48 each sell $7.11 each
knuckle seal list $48.77 each sell $36.58 each
axle seal lisy $27.62 each sell $21.54 each
q264462
HaysKSFirefighter
Valley Center, KS
Ok I also need the price for a oil cooler kit with cooler for a 6.0. Can I also get just the gasket kit for another 6.0 oil cooler install? I've already got one cooler just no gaskets. Also need thermostats, thermostat gasket, and coolant degas cap.
