25% discount on ford parts to members
Dustin34520
Nashville, TN
from what it looks like kinda a simple install but not sure if further programming may need to be done through keyless module to recognize keypad
keypad list $98.90 sell $74.17
keypad clip list $4.51 sell $3.38
jumper harness list $36.02 sell $27.01
and if you dont want to cut your door list $977.98 sell $733.48
q#264932
You da man! I really appreciate you looking into it for me. How long does this quote number last?
MossBack
UTAH
1997 Ford f-250 psd 2 connector valve cover gaskets and motorcraft glow plugs please...
Sent from my PC36100 using Tapatalk 2
sunrisefordparts
if i remember right the 08 and up diff covers will fit an 03' excursion right? if so i need a quote for: 08 rear diff cover, bolts, and gasket. shipped to 99615.
yes it will fit!
cover list $69.65 sell $52.24
bolts list $13.02 each sell $9.76 each x12
use silicone for gasket
q#265518
VQT
Parts needs for my Excursion
Can I get quotes for parts list below:
-OEM Oil Cooler rebuild kit - 3C3Z-6A642-CA
- HPOP Dummy Plugs/Standpipes - 6E7Z-9A332-B
- 6.4 banjo bolt kit contains (2)-W302472 bolts, (4)-W303659 washers.
- Turbo Oil Drain Tube -6C3Z-9T515-A
- Turbo Oil Feed Line - 3C3Z-9T516-A
- Turbo gasket kit/Mounting kit - 3C3Z-9T514-AD
- Updated blue EGR hose - 4C4Z-8592-AA
- V-code front springs 2C3Z-5310-HA
- Front U-bolts F81Z-5705-ZA
- B-code rear springs 3C3Z-5560-CB
- Left side 3.5" tapered block: Part #F81Z-5598-FA
- Right side 3.5" tapered block Part #F81Z-5598-GA
Thanks,
