25% discount on ford parts to members
SilentKiller71
Need quote
- stock front leafs 1995 F350 7.3 4x4 spring code T4F
- Front shackles
- 3C3Z-5560-CA
- Rear shackles for the 3C3Z-5560-CA springs
sunrisefordparts
Need quote
- Front shackles
- 3C3Z-5560-CA
front springs for that yr are obsolete from ford.
front shackles list $166.90 each sell $125.17 each
rear springs list $383.00 each sell $287.25 each, $50 frieght for pair
rear shackles list $49.65 each sell $37.24 each
q#281182
Buffalo444
Laramie, WY
lower b/j list $55.95 each sell $43.64 each
upper b/j list $65.70 each sell $51.25 each
lower steering bearing list $11.25 sell $8.44
upper small bearing list $8.30 sell $6.22
upper large bearing list $11.25 sell $8.44
****er bushing list $4.49 each sell $3.37 each
ps pump list $148.32 sell $111.24 w/exchange
all parts would have a 12 month 12k milage warranty, shipping would be free and we will include a return label for core.
q#280502
The one I have singled out, it says each. How many do I need? Also, are the ball joints greasable or no? This will determine whether or not im going aftermarket on those.
sent from the rust monster
Blacksmokin22
I need a quote on a 2003 6.0 oil cooler kit, hpop cover gasket, intake gaskets, thermostat, 2qts vc-9, the fat oring between front cover/intake, oil filter.
Would it be possible to also get a quote on a 08 black center console? Thanks
sunrisefordparts
i believe the b/j arent greasable i would have to order them in to double check. on the steering bearings the one that shows each would be the small upper which has an o.d. of 30.20 mm which is same size as lower one so possibly says each because upper small can be used in both locations.
sunrisefordparts
oil cooler list $420.48 sell $315.36
hpop cover seal list $17.18 sell $12.88
intake gasket list $14.43 each sell $10.82 each
intake gasket kit (only way other then front cover kit to get fat oring) list $112.43 sell $84.32
vc-9 list $26.50 each sell $19.87 each
o/f list $25.23 sell $19.43
tstat list $27.56 sell $21.22 w/oring
q#281345
sunrisefordparts
1997 f350 STD cab 4x4 front leaf springs shipped to 21901.. i see the 95s are discontinued but figured i would try
is there a possibilty you could get me a spring code, that way it will maintain factory height and ride. otherwise with wrong code it could lift front end or be to soft and sag.
zilla68
Moore Oklahoma
got my order on friday and the 2nd one today, thanks! you guys are going to break me, with shopping for oem parts this easy!
I'll buy the grill up this week, when I get back in town.
is the grill chrome with a gray type background/insert?
or is there just one style chrome oem grill?
