2WD guys... or anyone really for that matter...
MINK
London,OH
option 1 forsure....
BlueWaffle
Grapevine, TX
20x10 w/ -19 offset on the front and 20x12 w/ -44 offset in the back?? or keep em the same all the way around?
truck will be white for a while then likely a darker color...dark charcoal or gunmetal, true blue or some variation of dark blue. black is not completely out of the question either but not sure.
BlueWaffle
Grapevine, TX
as far as tires go...what size should I go with? i like a little smaller on the sidewall width but still want to fill the wheel wells proportionately. a 305 50 r20 is basically a 32x12.
1. would that be too tall
2. would that look stretched on a 12 wide wheel?
there is also a 285 40 r20 that would be 29x11.8...same questions as above...
JDub
Hooper, Utah
I ran 305/50 on the back and 285/50 on the front of my 2wd
Wheels were 20x9.5, don't remember offset or backspace though. Stock height in the front and a drop shackle with just the two full length leafs in the back.
Sent from my XT907 using Tapatalk 2
MINK
London,OH
Here is 305/50 Nittos on a 20x12
I like the staggered Idea but not sure how the offsets will look together.
BlueWaffle
Grapevine, TX
yeah that's a little too stretched for me. what's the backspace on those? isn't that what determines how far they will stick out? i'm cool with a little bit of tire sticking out (like 1.5-2") but not that far ^^^^...
MINK
London,OH
Offset is -44mm iirc
powerstrokin15
Charleston, WV
offset is what you should be concerned with on how far they stick out MM wise.. a -24mm would give you almost 2" like mine if I can dig up a decent pic
Sent looking at my blown up 6.4
powerstrokin15
Charleston, WV
found one. a 20x10 -24mm all the way around would be easy and look clean IMO. and would clear on 420s I think. ImageUploadedByTapatalk1360456946.497801.jpg
