35s on stock height?
bluedge8
Champlin MN
I really like the look of trucks when they lean to the back. If i got a 4 inch lift and just installed the front stuff and not the blocks or amything in the back, would that mess anything up? Then would 35s fit? And does anyone happen to have a picture of that?
Other than looking gay as hell, it would work. And yes 35's would fit in the front, could be close in the back.
btw, my truck has zero fitment issues with the front bumper because I have a ranch hand (currently) and is effectively "trimmed"
spencer922
Salem, OR
I had 35" Toyo muds on a 16x10 in wheel. They would only rub at all they way turned left. For me it rubbed on the leaf and nowhere else, but I did trim a little off of the bumber.
It looked mean, but I couldn't keep the truck clean with all the water on the road in the PNW.
pullandpray
Stock height.. bumper is spaced forward 3" and trimmed a little bit. no rubbing issues rims are 20x10s
redneckabbott
Jasper, AL
I had to trim the inside of my bumper when I ran 285/75/16. I've moved up to 315/75 and haven't touched my bumper again. I do have a 2" front mini spring pack I'll eventually install but the truck drives fine so I'm in no rush.
nossliw
37'S 16.5 Militarys on a stock 350 with an add a leaf up front due to a 500+lb bumper/winch combo. Probably sits near stock height if not a bit lower up front.
dieseltron
I have 315 75 16 on stock Alcoa's and they rub like crazy on my front springs. Mines a f250 so maybe a d60 might be slightly different.
dieseltron
Just finished the d60 swap last week and man does it turn sharper than before same wheels and tires. So I guess it does make a difference.
