Jhaddox
Double post
I have said this in a few other threads. But It really bothers me when everyone sits here and says that changing from stock, to a 3 link, 4 link, ect stopped there bump steer. It is not possible. No if's an's or but's about it. There is not a single way possible that changing front to rear facing control arms of any type can have any effect on bumpsteer.
I feels its a case of everyone wants to think it helps because you just spent a bunch of money on something.
Bumpsteer is caused by bad geometry between the side to side track bar and the drag link in the steering. The only way possible to not have ANY bump steer is to have the track bar and drag link the EXACT same lenght and on the EXACT same angle. Which is almost impossible in most cases.
As far as a parallel 4 link, vs a 3 link ( the two we are comparing here). There is really not a huge reason that makes one better than the other. The only main plus to the 4 link is it gives you the option to add some extra strength with the extra arm. That being said. A 3 link can be built more than strong enough.
One more thing to clear up. The factory set up is not a 3 link. It is a radius arm suspension. A radius arm suspension has two lower trailing arms plus a track bar. A 3 link has two lower links, 1 upper link(completely seperate from the lower links), plus a track bar. A 4 link has 2 lower links, two completely seperate upper links, plus a track bar.
I was thinking the same thing.
I would think if bump steer was an issue the area of concern would be the trac and drag link bars. There are kits that address this issue with the trac bar.
I agree totally although I am not one of those that paid a ton for my 3-link (bought used) nor am I a product pusher (only pmf product I own nor have I ever talked with Trevor) BUT everyone that has driven my truck agrees 100%...sense the 3-link went on there is a night and day difference in the control of my front end.
Have you drivin a truck with ala's or a pmf 3-link?
I went from aggrivated, to laughing, to just having a headache after reading that lol. "some" good info there though.
