4100 rpm with a potentiometer on the ICP
Blown262
Long island, NY
Pretty sure this is the answer to the question, lol.
Ever had this truck/engine on a dyno? Before you get your pride hurt, I'd call swamps i.e. golfer on here, and talk to them. They have a pretty deep background. May learn a few things the easy way, lol.
Yea that pretty much sums it up lol. I have had it on the dyno and I'm just breaking 600ft lbs which I was kinda bummed about, but I get great mileage so I can't get everything lol. I don't get my pride hurt over a truck putting down crappy numbers. It's doing something way past what it was originally designed to do so anything over 525 at the crank is wonderful lol
psduser1
on the road
Torque is not your friend...
Serious about the swamps thing, Dave has been around enough to forget more than 10 people on here.
psduser1
on the road
They have tested the electronics to the plausible limit. Not saying there is no way around it, but realistically, short of a mechanical or cr setup, I'd say they've explored the limits of the stock setup. More to the point, others have spent a considerable amount of time duplicating the research. And arrived at the same conclusions.
Blown262
Long island, NY
IIRC (truck hasn't been dynoed at all this year) I put down in the range of ~615ft/lbs and ~315hp
psduser1
on the road
What torque number should I be putting down with what's in the sig on a beans 150 race tune?
6-700. Like I said, torque is not your friend.
No more than 1k, and that would pushing it.
A big torque number is easy. So are vented blocks. That's why tuning has changed, a lot, in the last 6-7 yrs, lol.
Better to look at the hp curve, make that wide and flat, and give up the punch on the "bottom". Move the rpm range to 18-3200, on a stock block.
Saw your last post, that's respectable on stock injectors. (?)
Blown262
Long island, NY
Would moving the curve up be to alleviate excessive cylinder pressure down low? My Powerband doesn't even come into play until 1600 and it suddenly wakes up and drops off right around 3k. It really comes alive at about 2200 when boost peaks at about 26psi
Good point about the electrical side. I bet someone has a solution to that one also. I seem to remember some comments from other threads eluding to that. I could be wrong though, as my brain has gone to chit lately. Maybe stiffer spring and stronger electromagnetics. IDM would need to be beefed up too. Ported heads and aftermarket cam are a no brainer for high rpm operation. If the p-pump conversions can reach higher rpm's then the heui system should be able to get close once it's other short comings are addressed. Though I have not followed the p-pump thread well enough to be able to extrapolate.
No....7ms for the signal to travel from the pcm to the idm and then for it to actually begin to move the solenoid...well, 7ms. The hvhf idm helps but it is what it is..
Tuning advances aside, we're on the backside of this unfortunately.
he has prolly forgot more then most people even know on here.. he usually dont get into threads like this where its easier to talk to a fence post...
and ty nailed it.. well im sure ty pulled that from someone else's ass cuz he not a smart feller...
swamps idm is the only electrical upgrade that helps fire the injectors quicker.. thats it..
a better cam will alow more airflow due to the stock cam profile being so poopy for top end.. which it was designed for! my dually had a nice flat powercurve with over 400hp past 3200 rpm. stock cam and heads.. dont ask me how or why but it does...
psduser1
on the road
Yup.
Sounds about right. Big heavy parts, takes a second to get moving. About the time it does, you're outta fuel and air, lol.
You can change some mechanical parts, and make that window bigger. Different turbo, different injectors, and after about 7k in parts, you'll still be limited by electronics.
Sorry.
Blown262
Long island, NY
I don't know if I'm missing a sense of humor or if you're just tired of new guys. Either way, I joined this forum to share my experiences and learn new things. If I wanted to be ridiculed, I'd go back to basic. Ignorance can be a pain, I know, bit we all started somewhere
Blown262
Long island, NY
Yup.
Sorry.
Makes sense to me. No need to be sorry lol. I understand that sometimes things just are the way they are. It's an old truck and I don't forsee spending 10s of thousands to make it a race truck. I'd start with a better platform first
ja_cain
That's right, have to compensate for the delay. These things really need an aftermarket pcm/idm combo. You would think that with all of the 7.3's on the road someone would have come out with something similar to a Hondata. I guess diesels/7.3's just aren't as cool/trendy as gay azz Hondas.
It's threads like this that help solidify my knowledge of the shortcomings with the 7.3. Thanks for getting me straight.
Blown262
Long island, NY
So the shortcomings of the 7.3 are the trade off for a wonderfully reliable motor that can just keep pulling and pulling?
ja_cain
It is a wonderful motor as long as you understand these shortcomings. In my opinion, you reach a point of diminishing returns once you go over 400 to 450 hp. Longevity is most likely going to go to the crapper. 38r and some 160/30s for PMR's or maybe a slightly bigger injector and T4 mount turbo (BASB or whatever) for a forged rod motor is all you need for a well rounded truck. Though you could still probably stick with the 38r here too. Go with some conservative tuning from someone like gearhead and you should be golden.
Jermiahmercer had the configuration that I want to replicate and then went and sold it to get a 6.7 because he needed more room/comfort. I'm sure if he had his motor in a SD cc, he would still be driving it today. I could be wrong though.
Blown262
Long island, NY
Honestly, I'd be more than happy with 400-450hp. I have forged rods sitting in a box with some pistons ready to go if it ever calls for it. I have been on the phone with gearheads a few times trying to figure out the best way to go and I'm waiting to get a set of injectors before I go with another tuner, as I'd have to send my chip to them every time I need a reflash since they won't email tunes due to encryption fears. I guess they don't want people knowing their secret lol
I see no reason for anything other than a 38r in my truck. But im just runnibg little 250/200s...
Do the rods before you trash the block or tun a 238/80, keep the fuel light off idle, and start looking that day for a forged rod conplete motor.
