4EverBoosted1 Elite Built 6.7 Thread
O2ShootTheJ
so is this going to be daily driven or a play truck? cuz that could make a big difference as far as when 500 miles is hit
4EverBoosted1
It's going to be a mix. If I feel like taking it out on daily trips I will, or it may just stay hidden until play time. We built it to be daily drivable if needed.
MorganY
college station, tx
Sweet. We will drive to Dallas and back saturday, then do burnouts that Sunday morning. :lookaround: :gethim:
Sent from my SAMSUNG-SGH-I337 using Tapatalk
BlueWaffle
Grapevine, TX
do it. logan and coop are going to meet Kubik and I in dallas at the end of the month. bring that pile up here.
strokersmoker
The truck is running and we have been working out a few loose ends here and there but we can already tell just from idle that the truck will make crazy power...
When I play the youtube video I get a bit of a whistle/lope out of the processor on my laptop. I am going to have to upgrade to a Pentium for the burnout video!
Good looking build fella's
Dan
Fort McMurray AB Canada
I'm a huge fan of easy break ins... So you guys are gonna have to sit tight until I feel the motor is ready to unleash hell
But... But.... But....
Start it, let the coolant temp get up a bit, then full load full throttle on a dyno is how a Diesel engine should be broke in...
If they idle too much (slobbering away), don't get hot, or combustion pressures aren't high enough after a fresh rebuild the cylinders will glaze up and you'll have oil consumption/ blow by issues... Those rings need to seat against the cylinder wall and the only way to properly do that is with heat and combustion pressure...
At work after an inframe over haul trucks are immediately dynoed for 2+ hours for the break-in procedure...
I'm not very good at explaining stuff but all I know is this is a diesel...
2 stroke dirt bikes are a little different story.
4EverBoosted1
No body rides 2 strokes anymore.. I appreciate your input. You break in you motor how you wish, and I will do it my way.
