4r100 hanging shifts
Stroked550
I've got a 2000 f450 with 90k miles. On the way home yesterday it was shifting from 1-2 and 2-3 very late- 1/2 throttle, and wasn't shifting to the next gear until 2800 rpm or so. Once it shifted into OD the converter locked and it felt fine. At 35ish mph it wanted to stay in second at 2300 rpm or so. When its cold (first 15 miles or so) it shifts normally. I'm hoping its a VB or solenoid issue. Anyone have any thoughts/suggestions?
Mark Kovalsky
SE Florida, USA
I've seen this many times. It was always the engine not making the proper power. Fix the engine problem and the transmission magically was fine again.
Northwoods2002
Western Wisconsin
Stock or reman trans? PTO or no? Some more infor would help.
EDIT~ What MArk ^^^ Says. I was having reverse issues, turns out the seal on the pressure relief valve in fuel bowl was bad and I wasn't building enough fuel pressure.
Stroked550
Stock trans. Has PTO, nothing connected to it currently. Truck seems to have plenty of power, no issues once converter locks up in or. I'll pull codes tonight
Stroked550
After driving it today it seems the biggest issues is the 2-3 shift. Its about a 50/50 chance it will shift into 3rd. The rest of the time it will end up going into OD. Results of scan are below. Looks like I'll be picking up a speed sensor on the way home to start.
dieselflash
Ardmore,AL
Any luck with this? Im starting to have the same problem, haven't checked my codes yet and no o/d light blinking.
Stroked550
Valve body was hanging up, unfortunately trans was shot as well. Now has a freshly built trans with a precision triple disk converter.
