4r100 in 6.0
stroker57
frostburg,MD
That's much different then drilling new holes in the case. Thanks for clarifying
I drilled the two holes on the trans Greg is talkin about instead of the motor plate was much easier. Sorry for the misunderstanding that you thought I meant new holes I did mean the hole that were already there but like I said I couldn't remember right though there was indents instead of holes sorry
pipeliner
No need to change the flex plate stock one works just fine. Who's building your 4r ? As far as anything you missed you have to drill the bottom holes out on the trans. You don't use the the top holes at all
bts will be building it.
