Got most of my exhaust degreased, scuffed and sanded last night. Painted the tailpipe section first with vht 2k° paint. Used a torch to "cure it" but the stuff wipes right off. So i think ill use rustoleum on the rearmost parts and the dp and dp extension will get vht but ill try to put more coats on and let er sit until I can run the motor to cure it like the can says. I was contemplating using that flat bbq paint on all of it.
Anybody dicked with vht header paint before? Im wanting to use it on my bellowed uppipes and turbine housing. Does it work if you bake it on the truck? We have so much roadsalt that I wanna coat everything I can.
