6.4 egr delete - tube freezing?
TjMiller
Brick NJ
I just got an egr delete kit and before I go ahead and install I had questions about a thread I saw somewhere about a tube or sensor holding water and freezing in cold weather. Once frozen it caused the turbos to over boost. Sounded like this occurs only after the delete is installed. If this is true is there any preventative measures I can take while I am doing the install?
RedRice589
Ocala, Florida
That would be the EBP (exhaust back pressure sensor and tube. Totally different thing. Don't worry that's a simple fix if/when it does happen. I am lucky enough to not have to deal with it being in Florida others will chime in and explain better.
Powerstroke Man 6.4
I think the tube their talking about is the EBP (exhaust back pressure) tube
Edit
they beat me to it LOL
Fordtrucks
If its such a simple fix then please tell me what that is? This supposed simple little problem blew the head gaskets right out of my truck.
AKpowerstroke
Yes if you live in a cold are your EBP tube will freeze up and you will overboost if your not careful. A temporary fix if it does happen is to unplug the sensor which is located on the driver side near the HP turbo. The solution to the problem is to remove the old EGR pipe all the way to the up-pipes and install the EGR blocker plate right on the up-pipe behind the turbos. You will need to drill and tap the blocker plate and relocate the EBP tube and sensor onto the blocker plate. This was a PITA to do but I haven't had a problem since.
AKpowerstroke
Also when I did this fix, I found an inch of water had built up in my EGR piping that had been blocked off, which will freeze.
range91
michigan
ImageUploadedByTapatalk1389802000.495819.jpg I pulled inner fender and made this cut came out fairly easy just be patient and an extra set of hands are nice.
CT9AIX
MA
if you dont need the egr catalyst pipe on the truck for any emissions related reasons, delete the pipe, relocate the egr block off plate up top and mod it to accept the ebp sensor fitting and your golden. my ebp sensor used to freeze up, now since i relocated it up top life is good.... no freezing when your 6" from the hotside of the turbos lol
RedRice589
Ocala, Florida
I hadn't realized it caused the head gaskets to blow.... Jesus.... As far as I was concerned you could always tell because it would run like absolute crap. I overspend my turbos several times with no issues to heads. No reason to get wound up about it. We don't have the same climates so "freezing" isn't a factor. :pimp:
HD-tech-NH
5150 on two wheels
He said in another thread that he had head problems before this EBP sensor issue. If you monitor gauges you would catch this in no time.
QBall
Does anyone have picture of their block off plate mod? mine froze up today again... time to fix it...
QBall
Thank you for the link. I can't keep the winter front on with a heavy cattle trailer in tow. Runs too hot and the engine fan keeps kicking in.
