brettboat
So a stock fuel system essentially? Why not have twins with 1 feeding each head?
exactly how do you spend $10g in the bottom end? the rods are $2500 fire ring kit is $500, a girdle is $500, a block fill is under $100
do you just keep $5000 in cash in the pan?
and machining and balancing...you forgot labor
Forgive me Father for I have sinned
dam straight you didForgive me Father for I have sinned
Overkill for a commuter.
It's hard to do a fill in an apartment? I travel for a living dude
And a hypermax girdle is over $2k.
Figure in about $1000 for a rebuild kit. $2900 for rods, $2500 for a girdle, add in misc bearings and what have you $500. Lets say $2000 on the highend for delipped, valve reliefed, and ceramic coated tops and DFL skirts. Throw in some H11 studs, that's what? $850-900? So that's $8900 roughly. With machine work and labor on the half fill you're already at $10k. I'm wanting to start anew with a superduty block. Little more meat. If I could justify a hypermax block I'd roll with that, but only a small group of guys are running them and no street driven trucks that I'm aware of. Hard to justify with questionable longevity.
rebuild kit with delipped pistons was $1300 (adding valve reliefs isnt more then a couple hun) stock pistons are the only game in town so you cant spend here
rods were $2400
girdle was $600
arps for the heads were $565
fire ring kit $500
= $5365
still need a dampner at $600
if my machinist charges $4000 I am going to be pissed
