600hp/1000tq build sugg
Merc82
Sorry didnt remember but why the regulated return for the 190/30 injectors?
To make sure everyone gets fed at the soupkitchen... lol. Trust me, my psi drops at wot with my setup. I would look into the supply side as well with a sump/upgraded pump.
valvetick
Just buy a 6.4 ****** it and you have your 600/1000.....
Harleyx
T ville
Yeah aND then when your turbos go out, yup ure out a couple grand. Oh, then your hpfp goes out, let's pull the cab again and spend another couple grand. And then you still don't have studs.. versus a 6.0 you can access all of that much easier witg the cab on. For a 3rd of the cost. To each his own
valvetick
I have a 6.0 the 6.4 has its down falls but not near as many as our trucks..all of those listed above 6.0's are plagued with and more. And nothing can touch it stock with just a tune.
You're full of chit
powerstrokedkid87
New Jersey
Yea i plan on doing my trans first thing when i get back and are the pushrods and valvesprings not good at the 550 to 650 range?
its not that the stock ones are bad, its just cheap insurance for a larger setup. I recommend upgrading in anything over a stock size charger, or powermax. Last thing you want is to have to go back in and pull ahead off. For the money, it would be a wise purchase.
the regulated return for exactly what was mentioned. To keep all the injectors fed adequately and evenly. a fuel pump is also a good idea. You could get away with a stock pump, but an upgrade again will keep injectors from loosing fuel pressure.
When you get into trying to make a more power, you have to add the supporting mods. It may seem like your spending pointless money on parts that may not per say add power, but you need the additional parts to help optimize the parts that do add HP. You can risk not doing the necessary supporting mods to try and save a little money, but cheaping out will most always cost double in the long run.
046.ohBills
Middle Georgia
I understand completely, I planned on doing the supporting mods for it, just not sure exactly what supporting mods to get that would be pointless if you know what I mean. I was thinking about doing a larger fuel pump but whose regulated return kit would you suggest?
046.ohBills
Middle Georgia
For this build to 1000 tq a lot of guys have been saying 190cc injectors (30 and 70%) but what would a 175cc75% nozzle be able to do? would that help with the 1000tq number and be able to support a kc stage 2.5 turbo to the 1000 tq number?
Halestorm55
Skiatook, OK
Couple hundred. Go check out kcturbos redemption build thread. Those temps are with 190/30's. 75's would be a bit smokey and work better on a 205-285 to stay close to factory cc/flow ratio.
looking up parts
046.ohBills
Middle Georgia
looking up parts
ok right on, I figured the 175/75 would be easier on the stock pump then 190/75,190/30. but if it wouldn't then I guess it wouldn't matter. Engines don't like heat lol trying to stay away from that when I have to tow.
046.ohBills
Middle Georgia
You can do 175's but bigger than a 30% nozzle isn't necessary on a 175
I'm assuming that is because the 30% flows the 175 to a point where any bigger is pointless?
KC stage 2 and 190/30's is a great setup for the street
I heard kcturbos say that and he suggested the stage 2.5 for quicker spoolup which in turn is a slightly higher tq number if I recall correctly. still streetable, dd, and tow capabilities. would you agree?
