6L Headers... A few questions..
Status
Not open for further replies.
strokin6L
Springville NY
Blackwidow diesel and Maryland performance diesel make some nice log style manifolds made out of stainless steel that help with spoolup. Craig at MPD said he noticed them help alot with that.
patrickke
Lexington,ky
One of the guys from MPD posted in this thread...I asked them a few questions and never got a reply...
patrickke
Lexington,ky
I'm just wondering if at some point the stockers aren't as good as something aftermarket designed for a high hp application...
Powerstroked162
On Da Juice
Wa. State
I'm sorry but the manifolds available for the 6.0's don't beat what stock does. You cant just grab some pipe tee's and 90's, TIG them to a flange and expect them to work. There is way more work involved then that. 9 outta 10 times you actually cripple yourself doing things like that then you do knowing the cause and effects of the design, each piece, bend used, as well as material choice, etc.,
Powerstroke Racer
Brenham TX
Headers are better than the stockers period end of story and anyone that says otherwise is a fool. That said headers are not for everybody, but some of us that understand how things work want the best responding daily driver trucks out there and as such build them accordingly. We run them on all of our daily drivers with ZERO problems but I also do my own tuning and installations as well as use my own turbo mounts although I think the TN setup is ganna work out real well.
Now why are people saying not to use them???
Simple, they had a bad experience with them(yes BAE is aware of the problem). Are they fun to install ?? No but neither are injectors or turbos but we do it anyway for what they give us.
Craig@MFI
hmm seems to work pretty good if you ask me we have 0 drive pressure issues and spool up on a s475 is like stock and can run 10.40s on fuel.......
Craig@MFI
sorry about that we have been testing them and waiting for our cnc machine to get fixed before we can make more flanges
The only thing we have them running on is whitey and that speaks for itself as far a spool up and the way it runs
we are currently installing them on a truck with a 66/71/.76 and well post up when we are finished
Thanks
patrickke
Lexington,ky
Do you have any 6L headers on any trucks? Any before and after comparisons? I'm not being an a$$ I'm just curious as to the changes with them.
patrickke
Lexington,ky
Thanks
What s the price ball park on these?
Powerstroked162
On Da Juice
Wa. State
Did you get my text?
Sincerely,
A wise fool
Powerstroke Racer
Brenham TX
Sincerely,
A wise fool
No I did not, but a crack in a weld does not mean headers are not a valid performance item. Interesting thing is that my personal trucks as well quite a few customers daily drivers perform very well on fuel and make great daily drivers, all with stuff( headers,cams,ported heads etc.) that supposedly don't work.
oh the irony of your sig there, priceless.
strokin6L
Springville NY
Sooooo, to make a bold statement like that...you obviously must have ran a set of headers or aftermarket manifolds on a 6L then right? If not...it's mearly just a worthless opinion of yours.
Powerstroked162
On Da Juice
Wa. State
Call it a worthless opinion or a proven fact, I don't care. Its pretty much known by juuuust about everyone that the 6.0 manifolds are the ticket in a build, all be it a 6.0 or a 6.4
Do you have access to a set of calipers? Solidworks?? Barnes and Noble??? a flowbench???? These are all things you will need to become familiar with to learn for yourself the cold hard truth since somebody spelling it out for you with alphabet letters on a fridge just isn't clicking.
And to sooth your discomfort, yes, I have been in on a little bit of testing, a little bit of removing and replacing, a little of everything. I wouldn't be in posting up if I hadn't
Regardless, its YOUR truck and YOUR money, so do what you please. Just remember, the question was asked and we gave answers, whether you agree, disagree, don't understand, cant comprehend, whatever it may be.
Best of luck in your venture
strokin6L
Springville NY
Hmmmm yes 6L manifolds have proven to be good at 1000+hp. Doesn't mean an aftermarket set of manifolds(not headers) would flow a bit better . As it was already stated and proved by Craig at MPD that they did infact make a difference. And i've already talked to some with BWD's stainless manifolds and have experienced the same great results that Craig had said. Soooo the question is...do you not understand, can't comprehend that they just might help some? Maybe you need some more testing.
Powerstroked162
On Da Juice
Wa. State
Good luck, you're gonna need it
patrickke
Lexington,ky
I wish I could do a back to back test on stock manifolds, modded stock manifolds, stainless manifolds, & headers on a 6L... it would be nice to see anyone that has used aftermarket manifolds or headers besides mpd, just so we would have a little more unbiased view...
6.0dirtworker
Cloud 9
:whs:
Status
