I originally posted this on the wrong thread, so I'm sorry if you're seeing this twice.
So, I've been looking and looking for a 99-03 7.3 SCREW cab to replace the rusted out one on my 01. After reading a lot of different things all over the interwebs, I'm a little confused. My thinking right now is that I could definitely use the 07 cab that I found, along with the 07 dash so long as I use all of the wiring harnesses from the 01, but I will have to swap the plug for the headlight switch, and maybe have to patch a piece into the firewall where the PCM passes through. Otherwise, everything should bolt up and transfer easily. Is my thinking on track or have I missed something? The cab I found has a decent interior, so that would be a decent 6 year upgrade. I also found an 02 cab, but would have to transfer my interior over. I just need to make a decision.
Thanks for any input
