700 hp goal build
Magnum PD
VA
Dual SD fuel pumps work fine for me.
What is a tweaked Honey Badger Jr pump? Need big oil for 300/200's
joe d
monroe mi
I was going to say i know my 238/100 have never moved my fuel psi gauge. But those are babies conpared to a 300/200.
powerjoke73
If I go areomotive or fuel lab do I just need to buy the pump and switch it out with the Bosch in my system?
powerjoke73
dont quote me but if I remember correctly, it is the pump that they plan to make available for this size injector. Hopefully Jason from Dyno Proven can chime in and answer that question fully
powerjoke73
I have had a kit. I bought a complete fuel system from Dyno Proven. They told me that the single Bosch could keep up. So I am assuming I was going to still run the stock pump with it.
powerjoke73
However, it has been suggested that I upgrade so I am trying to decide between the a1000 and the fuel lab equivalent.
since when are 300/200s a 700hp injector?
is that a stocker bosch pump or a 044 bosch pump? ..
be cheaper to go woth dual stocker bosch pumps and just as reliable as any of those expensive pumps since you already have one?
Lt.Dan
Visalia, CA
Sorry to jump in, but i have a quick question.
When you run dual stock pumps, do you run them inline with each other? Or one feeding each bank?
emev0l
Sump or 5/8" draw straw into 5/8 line into a 3 port filter base/water seperator, one 3/8 line out of the other 2 ports each into a stock pump then 3/8" each into the 2 ports on another filter base/post pump filter, then a 5/8 line into a regulated return. It has been done different ways but this way allows you to drive home if one pump fails, if one pump failed going to one head it wouldn't go well.
Powerstroker7.3
waxhaw NC
300/200 have always been enough fuel for 700hp. But other supporting mods and tuning advancements have made it easier to hit that goal. Take Matt for example he fogged his intake and made 1200hp with 350/200.
m_j
good answer. heads are the bottleneck now
psduser1
on the road
I think airflow would be the limiting factor, i.e. heads and maybe turbo, depending on how "clean", and driveable you want this to be.
Port work is expensive, lol.
