black974door
- Joined
- May 18, 2011
- Messages
- 78
- Reaction score
- 0
what all do you have done ^^
mine would de-fuel and wouldnt throw a code. just felt the truck bucking at higher boostI ordered a fooler that should be here Thursday, hopefully that will negate all problems i may be getting.
Apparently even if you don throw a code, could still be defueling slightly! WIll be interesting to see how much of a difference this little gem will make
I would like to find out more info on this. I will try and email Joey.
Jeff
What maximum ICP do you guys like to use?
I know there is a grey area on what works and what doesnt, everyone has their own opinions
Real close to 3000psi on mine.
I only have a 17 deg pump so I think that is pretty good. I know some have good luck with higher ICP and some with lower.
It has been know for some times about the overboost problems, some don't have them, some set a soft code and there is a rare occasion some even set a CEL.
I run an ITP on my '97 and it runs fine, I switched to a dieselsite one time and it made the truck run just like you pulled the chip out or similar. Normally it would make 45+ psi of boost, but with the blow off style fooler it seemed to make it stop at 30. I don't know what the difference was that made it run so much worse, I figured it was something in how it was seeing MAP pressure affecting the fueling.
Getting back to the different PCMs of the same code running different in different trucks, Some will call me crazy but I have sworn for years that even a single PCM in a truck will run differently from key cycle to key cycle. Out of all of the OBS trucks I have owned they all have seemed to have times where they would run ok in general but sometimes the seem to run acceptionally well or bad And that all can change in the same day.
-Michael
