dozer
JD you've got me motivated! 71 arrives tuesday!
So I did some datalogging last night in the truck. Did a WOT run to ~100.
Max boost- 49.4
Max EBP- 84 (absolute)
Max EGT's- ~1600
Ambient Temps were about 85*
I think this was missed.
On the EBP, that would put you around 70. For DD (non-competition) truck with stock valvetrain, would you agree that 70 PSI (84 absolute) is the very max to push it to?
84-85 absolute is as far as I would go without a gate.
I am wondering why it is so high? I know Jeff's truck is lower than that. And the highest I ever see at any rpm/ throttle position is 55-56 (55+14=69 total). This is on the Spartan 310. I have my voice alert at 60psi and it has not gone off since swaping to the 71mm.
Does your exhaust include a down pipe
Altitude should play a big factor in that. My turbo has to work hard to move that much air.
Everyone I see with the 1:1 at wot are monitoring with dashdaqs
Thats just because you have the option to monitor it with or without amosopheric pressure. I don't think any other monitor does? I like without as it makes more sense to me when you are watching it next to boost.
And if it matters. Which I can't come up with any practical reason why it would. My EBP sensor is in the driverside exhaust manifold.
