jdgleason
Hey JD, if I missed it somewhere my bad but would you still say with this setup a wastegate is not needed?
It wouldn't be a bad idea at all.... I am right on the verge of needing one.
If you're reading without barometric, you're reading EBP desired. That isn't the actual number you're seeing. It's desired, meaning that is what the computer wants to see. At some points it's spot on and at other points it's off. Reading absolute and doing the math is the best way to do it.
Didn't know that. I have both. One under the other. They seem to always be the same 14 apart. That being said i believe i have the warnings set at 60 and 74 and i have not heard either warnings since the turbo swap. either way. For whatever reason. My ebp which use to be extremely higher than your average truck. Has been lower then your average truck ever since the head studs were done.
I have dash daq and I read it by absolute. Do you subtract or add barometric? I believe someone correct me but its 14.6 or something like that. If I subtract it on mine I'm around 1 to 1. If I say running 15 boost my absolute is 29 to 30. I havent did no data logs I'm just going by watching it.
Ok thanks JD. So im running 1 to 1 as good ad it gets. The reason i asked about gate because somebody told me the 71 shouldn't change ebp if anything should lower it some. Like ipkyss he ain't having trouble and in running good ebp now so I was just wondering. It seems a few ebp are in good range with it and yours is on the border.
Yeah keep forgetting about altitude. B585ford when towing does your ebp stay at good ranges even pulling hard?
Tuning Update?
no changes other than the head studs, push rods, wastegate. I obviously assumed it was because of the wastegate. Later removing it when I realized I didnt need it.
Do you think the low EBPs is related to your "low " dyno reading at Rudy's? Correct me if I am wrong but your trap times suggested around the mid 600s so it looks like the dyno number was off
Congrats JD 12.86@104 at 6000 ft with a 1.75 60ft. My guess if he came down here would be a 12.6 or better.
