Aftermarket valve spring discussion
907DAVE
AK
I think the ratio's are close to 1.6, so multiple that by .2535 and you get roughly .40 lift.
Cota
So where do the Hypermax high rev valve springs fit in or did I miss it?
Tim @ P.I.S.
Sunny, FL
This was posted in the past by Machinist......
Numbers I got
Installed height is 1.800-1.810, subtracting the .045" thick integral shim/seal gives us an effective installed height of ~1.760" with all stock components.
New Stock spring
110# seat pressure
250# open @ .410"
.070" to coil bind
~350lb/in spring rate
Comp 910
120# seat pressure
285# open @ .410"
.070" to coil bind
~400lb/in spring rate
Hypermax @ 1.615" installed
150# seat pressure
330# open @ .410"
.130" to coil bind
~440lb/in spring rate
JDub
Hooper, Utah
I would have to double check my notes, but that is about what the Crowers came out to also.
Our springs should be around 145. Ran them on every motor that has come out of the WOP shop since 2004. Ran them in the dragster which has seen 5200rpm multiple times, never an issue, WOP Race Cam and cryo treated stock rockers.
slim613
anyone ever find out any more info on these im doin a build with 910 and 0.030 shims
