Air management
Arconalloy
Warner Robins, GA
Is there anyone running any type of auto air management systems under their trucks for bags? I want to run a compressor and tank setup where my spare was so I can add or reduce air pressure with ease. I've looked into a few but curious as to what you guys that have experience with this subject recommend and run?
Thanks everyone
Sterling6.7
Are you talking about just for rear axle bags, full air ride or somewhere in between?
Arconalloy
Warner Robins, GA
Only rear bags I am running a set of carli long travels
Arconalloy
Warner Robins, GA
I see what your talking about now it's called the wireless one. I would like to simultaneously fill both bags like that but would like a tank set up I can run a separate line off of for general use as well
zporta
Are you referring to just running an onboard air system with rear helper bags?
Arconalloy
Warner Robins, GA
Yes for rear heloer bags. What I'm looking to do is have on board compressor and tank mounted under the truck tied into both rear bags so I can control the psi in the two simultaneously when I need to from remote or inside the truck plus have a general use air line split off the tank as well for air anywhere when needed. Looking for a 100% duty cycle compressor by the way
WHY NOT
Carlyle IL
I run firestone air bags and an Airlift Wireless One compressor. Its simple and small and have it above my spare tire. I don't have an extra tank just air the bags up and down with the compressor as needed. There is nothing wrong with the airlift bags either we have just always used firestones and had good luck with them
Arconalloy
Warner Robins, GA
I would go that route if I didn't want a spare air line for other things. Might throw a hornbladter horn under there as well later who knows
HOUTX01X
I like my firestones. The only issue I had was the fill line broke and I lost all air in that bag. Ended up ruining it. No biggie they sell replacements
zporta
I have an airlift on board air kit with their load lifter 5000 kit. Exactly what you are wanting to do
Sterling6.7
I had a bad experience with an Airlift controller on my previous '02 and I swore a better install this time around. It was an auto controller and the pressure sensors went bad and I couldn't get replacements. It was almost uncontrollable at best. I ended up putting a power switch on it and then manually controlling the bags and then turning it off so the automatic operation didn't take over.
This time I started with a manual setup and Firestone bags. When it is done, I will have tank and bag pressure readings on the CTS and electric solenoids for the independent bag fill and dump. I currently have the dual gauge and pneumatic valves in place below the cup holders until I can get some time to dedicate some energy to completing the install.
zporta
Mine isn't hooked directly to the compressor but to the tank. So the compressor fills the tank to 140psi. My switch fills the bags and releases air as well. One needle reads bag pressure and the other reads tank pressure.
TripleStrokes
Cincinnati ohio
I've been running Firestone bags with a Air Lift wireless controller for 5 years now and love it..but if you live in a freezing climate i definitely recommend air line alcohol.
But with an air tank you might consider a more cfm producing compressor.
