Another cracked piston
webb06
Seneca, MO
You need to check compression for sure. A buddy of mine owns his own shop and did about 10 grand worth of work on a customers truck (ported heads, RCD turbo's, springs, pushrods, manifolds and up pipes head studs etc) and it cracked a piston on the first test drive with the H&S still on stock.....
Sent from my SPH-L720 using Tapatalk
Ouch Charlie
6.4strokin
Stock pistons?
Sent from my iPhone using Tapatalk - now Free
WoodBoy
Alabama
Thanks for the uplifting post...
LOL
I think the heat cycling is what causes failures. Jumping on the throttle and spiking the egts and chopping the throttle and shocking the piston face with cold inlet temps.
How are egts on those trucks. They seem to.get warm from.what people have told me, alas, I do not know personally.
A friend of mine with deletes and tuning said his.gets up to 1k° just accelerating to interstate speeds! :eek: seems like a fairly hot system especially considering the sequential turbos.
Just looking to learn a little something!
jdgleason
Fort Collins, CO
Trucks with DPF's on them run like 1350* in regen at an idle sitting at a stoplight.
They are no stranger to high temps.
Mine gets to 16XX* at the end of the track with dual pumps at altitude.
webb06
Seneca, MO
Have you actually monitored this? I asked an instructor I had about this and he said that its wrong and that the real heat is in the dpf
jdgleason
Fort Collins, CO
Mike Haller's old blue truck got the dpf put back on it, but he still had a dashdaq - he said it showed like 1350*
Rmartin-97
Mcarthur ohio
What was your issue?
I think the miss had somthing to do with the crank case bein over full. I drained the crank case and it doesn't miss any longer. It idles fine now to. Just been lettin it idle with the cake covers off makin sure no fuel is leaking from any lines or anything.
