another e4od question
kadeninabnitt
Martinsville, IN
My trans is leaking where it meets the tcase. now my question is there a seal where the output shaft comes out of The tail section. or is the gasket between the the trans and tcase supposed to keep the fluid in. I've searched for a seal and all I come up with is 2wd seals
Wes Lewis
Pittsburgh PA
There's gaskets there, 1 on each side of the adapter between the trans and t case.
Make sure the adapter itself isn't cracked, had that happen before
Tiha
Super Moderator
Super Mod
Is there one around the converter front of tranny?
There is a seal around the convertor. Do you have oil dripping from the bellhousing/inspection cover?
Pretty common for them to start leaking.
