BD Diesel 6.4 Tap Shifter?
drunk on diesel
Erikclaw
Central CA
So using this tap a shifty thing makes you want to ride shift levers and be gay part of the time?? I pass, no spit before you sit, manually shifting gay porn here......
simonton6.4
Monroe,Ga
Mines working fine but every time I use it I throw a wrench light have no codes that pop up on the cts. I can turn the truck off and cut it back on and it goes away?
tbsimmons
Bakersfield, CA
Towed pretty heavy this weekend over a pretty steep pass.
I need a new trans and or TC if I want to use more than a tow tune and towing. Anything higher than a tow tune the big bitch doesn't want to downshift and makes either the TC or OD clutches slip.
The tap shift is not full manual. It works great but I wish it was full manual when activated. It is great when holding a gear going down a grade but it still allows a downshift when climbing which my truck doesn't need most of the time. The downshifts are based on throttle percentage by what I can tell.
Sent from the bat phone near a drilling rig.
Powerstroke Man 6.4
How about "race" mode did you try that?
