tbsimmons
Call BD. I think they released it a little early without testing.
Sent from the bat phone near a drilling rig.
i think the more likely scenario, is if you had a stock truck there wouldn't be any issues.
otherwise the r&d time to test your product with every available tuner would be rediculous, not to mention pointless.
sounds like they picked a few of the more major ones, got them mostly figured out, and are now running into some one off issues.
though their willingness to help resolve the issues that are arising from the use of aftermarket tuners is commendable.
just installed the tap shifter on my truck and upon the initial start up it wouldn't start. All I could hear when turning the key was a click. with help from (powerstroked08) he had me go into the diagnostics on my mini maxx and erase all the DTC's. There were several DTC's but the 2 that popped up after the tap shifter installation was an exhaust gas regulator flow or something like that and also there was a communication error. Everytime I start the truck I have to erase these codes or else the truck won't start. Going down the road the truck runs funny. The fan is almost always on it reaches 1000+ egt's very quickly and abnormal turbo sounds. Also when I go to delta the codes my mini maxx sometimes work and sometimes doesnt. Has anyone had any of these issues?? Could wiring be hooked up wrong or something??
Thanks guys,
Troy
Anyone know why when I plug the tap shifter in I get an exhaust gas recirculation flow code? When the mini max is plugged in by itself everything is fine but when I plug the tap shifter in along with the mini max it throws that code and the truck starts making weird sounds. Thanks
In 6 3rd will lock up too but not 1st or 2nd.
Mine goes through the gears so fast I am only in 3rd a short time.
Just looking for updates to see if guys are still having issues with these? I have wanted manual control over shifts since I bought this truck and was thrilled to see BD bring it to market. I just sold some stuff so I have the money now to buy one. I mostly want it for towing. I live in western Pa with tons of hills and the truck likes to hunt between 4th and 5th on the hills way more than I like. I'd rather just put it in 4th and leave it there, but there's no way to do that. I have a Mini Maxx with canned tunes and a stock tranny.
One question with these: they say that you can control TC lockup and shift points. How is TC lockup controlled?
