OSCS
I looked for the tutorial but I could not find it.
Is it necessary to jack the engine?
Yes
:thumbup:
i understand your point. but you as well as oscs uses coolant cost as a direct relevance, or hindering factor to pull or not pull a engine(oscs called it a "waste of money") (it's the way bolth of you brought the cost of coolant to the table)
wtf the chit only costs 13-15$ per gallon.
if coolant cost means that much to you? can you/ should you really be modding your trucks, money wise?
at the end of the day, whats the argument worth. most are going to torque the heads down with a pos harbor freight torque wrench, thats about as accurate as a one legged ass kicker. motor in or out. then bitch once something happens. (i dont understand. i did everything psa told me to!!)
lmfao
:thumbup:
lmfao
:thumbup:
lmfao
hey im not going to go round for round with you on this. you do it your way, i will do it mine.
as far as the heads being off? with what the op has done to the truck,and what he will be doing, why wouldn't you look the heads over, check the valves, and seats, guides, etc.
carry on fella's. im done here.
:thumbup:
lmfao
That or drill a big hole in the firewall to remove a headbolt, and remove the A/C box on the passenger side. Or pull the motor.
you did that for ARP's?
