BPD water pump
Diesel625
Looks I’m going to change out a water pump again. I’ve always used oem Motorcraft pumps, but they seem to only last 2-3 years. I’ve never had an impeller break, just leaks from the bearing. Are the bpd pumps that much better?
Diesel625
No. I actually had issues with a kdd long block and had to get studs again and went to Powerstroke products head too. I did have issues with fan clutches a while back and swapped a few. It may have been something to do with constantly swapping the clutch’s and breaking the clutch loose. Not sure. Haven’t had an issue since I installed a new Motorcraft clutch.
Diesel625
I looked back in my service records and I actually replaced it in May of 2021. I guess 4 years isn’t too bad after all.
